auto2
06.15.2008, 11:24 AM
cause I have these fans i bought that are called magnetic levatation fans? or something like that. they flow like 6 cfm and run at 9000 rpm at 12 volts. i had a fine design motor that waS running 170 after a few minutes and this fan cooled it to 125. plus they never break.( so far) it would fit perfect on the heat sink if the top of the case was acidentlly removed.:-)
you know another serious option is liquid cooling like boats do. a convection set up with no pump. no moving parts, nothing to break.
