George16
Supermaxx
George16's Avatar
06.15.2008, 08:04 PM
Originally Posted by BlackedOutREVO View Post
George, Dang what diffs are you running?
I'm currently running 6 spyder 1/8 scale diffs. I will be removing them in a few days and will be installing a pair of UE 8 spyder 1/8 scale diffs with 5K front and 3K rear diff oil. Current diff cases are UE Ultralites but "might" be swapping them out for my VBS .
Here's a link to my brushless build: Gmaxx build
Edit- One thing that I did to the 3906 shaft to strenghten it was removing the pressed pin, drilling the hole to 2.5mm, and then installing a hardened pin from a plastic yoke setscrew.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
