TDC57
TDC57's Avatar
06.16.2008, 12:21 AM
Originally Posted by TruckBasher View Post
Shaun,
I've read thru the thread but somehow I missed out the part you've used to mount the 3905 transmission. Is that a customer made alu mount or is it something you can buy. I have a center diff with my gmaxx (old version) but I am planning for the worst in case i ruin it or something. I just dont see the slipperential on the rc-monster store. Also I dont like the setup since the motor is only on one side and unbalanced..
THanks,
Jeff
Good evening Jeff,
Here check out this thread, it outlines for you the process you'll need to go through in order for you to do your conversion.
http://www.rc-monster.com/forum/showthread.php?t=11650
You will also need to perform the shortening of the output shaft if you are going to install the 3905 Trans. Here is that thread as well..
http://www.rc-monster.com/forum/showthread.php?t=11589
Hope that information helps??.
Thanks for your time and have a great week Jeff.
Shaun.
Nothing!.. Hahahahaaa..
