Pdelcast
Pdelcast's Avatar
06.16.2008, 07:24 PM
Originally Posted by Revracer View Post
well I just talked to Joe at castle and he said the way mine is it should be absolutely fine. I told him how it gets hot and to the point where I can only touch it for a few seconds before it burns. he says his will be so hot that it will melt skin and it will still run fine. is that right? my bec is coming out soon anyways. ordering a ccbec tonight. and ill get a nice cap on there too.
ps: briang - i like the binary sig... hahaha
Well, if you can touch it for a couple seconds, you are in the 140-150 degree range (approx.) The MM is designed to run to 200 degrees, so you should be OK.
Patrick
Patrick del Castillo
President, Principle Engineer
