tc3_racer_001
tc3_racer_001's Avatar
06.17.2008, 01:54 AM
i dunno, maybe a plastic spur (u will need shims to do this) and more voltage OR a higher kv motor... i havent recieved my motor, but i ordered a 2550kv neu. this will give me the ability to add another 2 cells in parallel (and then wire into series) to give me 5s2p... im going to run 4s2p, and with less than 6 or 7s id suggest you do 2p too... its just NOT enough amps... or runtime!! 600g is comarable to those running 8K maxamps packs. its less than 100g more than the typical lipo setup anyway :)
u will also need a mount of some sort, either make your own or buy the hyper mount... have a look at my build and see if you will have the same issues as me. shouldnt do as i think its a direct fit :)
hope this helps...
ryan
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
