06.17.2008, 04:09 PM
I agree with the idea of why put cell size/ voltage limits. Seems silly. The limits will be found by the vehicles and the weight. If you want to run 4s 6000 then do it. If you want to run 6s 3700mah. They should both create similar power and run times. Its just that one is done with volts and the other is done with more amps.
I would love to see a 4s 5000mah hard shell pack in a single pack format available, and for that matter a 5s 4350mah hard shell or a 6s 3700mah. They would all be perfect size for 15 minute 1/8 buggy races. Then Roar doesnt have to worry about voltage or capacity standards. Just dictate some safty standards and be done with it.
to make it...
or break it...
Silent...But Deadly
