06.17.2008, 11:04 PM
Originally Posted by Daddydancool View Post
ok great i also have this motor in stock! i ran it in my t4 before i switched for a mamba motor!
if the shaft is smaller, i just have to use a bore reducer?
last question, with the 6l, what kind of pinion shoul i use? i'm not looking for a top speed record, (especially with a 2s)
Thanks
Yeah, you need a hardened pinion to run on the crt.5 steel spur. Rcm sells the bore reducers to fit the 5mm bore pinions on a 1/8 shaft. I would go with a 13t pinion to start, and see how that does.
