bustitup
06.18.2008, 05:04 PM
Originally Posted by Django View Post
It's the wire. On my packs they come out of the corner of the pack. Although the wire is very flexible, it isn't able to make a 90* turn and come up and out of the provided wire notch in the battery box. ONe of the packs will sort of work if you put a lot of pressure on it, but the door is flexing itself to make the catch. Not a good situation. If the wire came out of the middle of the pack, I could cut the fins out of the exit vents and route it up and out of there.
What brand 6000mAH packs are you running? Link?
I have those packs 15c and the wires come out the middle of the pack as stated on the truerc site...do you have older packs?...got mine about two weeks ago
ooops just niticed you were refering to maxamps....mine are truerc 2s2p 15c 8000mah
