06.20.2008, 12:54 PM
Make sure that you have all of the trims centered and no exponetial or any other settings off zero. I have a 3pm and it can be difficult to program at times. Have you tested the radio and receiver by themselves? By using a rec pack and some servos? Do you have the same xtals, or the synth set correctly? I would fully test the radio and double check all of the settings first.
