GriffinRU
06.20.2008, 04:31 PM
The DirectFET is a great package -- but IRF silicon sucks. (Infineon is releasing some DirectFET mosfets soon...)
You will be ahead of the game if you supply IRF with right silicon and get your own fet's. While it would take some time for Infineon to release new package. You know that packaging is the major problem in microfabs. If IRF knows how to package it would be no problem for them to process "your" silicon.
Ok, I will try to come up with software, you convinced me :) Done that in the past, so not a big deal, as you said hardware is relatively simple :)
See, I was hoping you write software, I will do the hardware - the output stage...and then even open source it -> deep inside I think it is the hardware which is complex. Software only become complex, when has tons of bandages and solutions to overcome hardware flaws not limits, limits must be identified at the design stage.
