Originally Posted by magman
I am going to purchase the Neu as soon as Mike gets them back in stock. My question is this...the Neu is 2050Kv while the 9xl is 1850kv, even though the Neu is more kv and spins faster would I see about the same runtime with both assuming the setups, were the same..(MM esc w/ 4s)..due to the efficiency of the Neu? Just curious.
2.5d is rated @ 1650 kv
2d is rated @ 2050 kv
the run times might be comparable due to the Neus better design and you will probubly be disappointed with the performance with both motors on 4s, if 4s is your only power option go with a 1y or 1.5d
