06.22.2008, 08:43 PM
Well actually, I'm considering a pair of these ESC's to power a pair of Mamba Max 4600's in a boat.
I wonder if I could run a single pistix adapter through a Y connector to control both ESC's.
You should be able to do that. You may have to setup each esc individually and then plug the y cable in.
What voltage do you plan to run? If 4s or less, the aquacraft esc from the supervee 27 is pretty good and not very expensive...
