Django
06.23.2008, 03:21 PM
Originally Posted by azjc View Post
does it look like there could be a way to cut out part of the chassis where the battery compartment is so the battery wouldnt be completely enclosed? or would this compromise the strength too much
On the left hand side (stock ESC side) you could cut the top of the "box" away and be able to put batteries that are taller than 30mm in there. You'd need to have some sort of shelf over the front or rear shocks so you'd have somewhere to stick the ESC though, obviously.
The right side of the truck still wouldn't be as easy as the stock two motor, motor mount hangs over more on the right side than it does on the left. Once we can get our hands on a traxxas single motor mount (or get something else to fit) we might have more options.
