lipomax
09.30.2005, 04:45 AM
You could measure the amp draw under no load situation. Each motor draws slightly different amps under no loads. You can find the data at motocalc for the no load draws. In addition, are you sure you got the right gear ratio for the tranny? The right size tires?
