06.27.2008, 10:31 AM
The MM Pro doesn't yet exist and when it will it won't support the Amps for a truggy.
5S could be pushing it on a MM to but many people have had success...
I think you might be better off with the ESC at that back closer to the motor and battery. I came out with a clean setup which I can show later.
What is your issue with the front brace? Did you realise the order of assembly is a little off. You need to postion the front brace BEFORE putting in either the centre diff assembly or the front top plate...
It should in theory support the amps. Pdelcast said they would be about 90% of the MM, so ~90 amps. The motor I'm using only pulls a max of 78 amps, so I should be fine. Not sure about the 5s MM thing- I can get a burnt MM off of my friend for hardly anything and get it repaired by Castle, but still it's a waste of $50, and how hard is it to disable the LVC? And about the front brace- I did remove the aluminum plate and the center differential. It sticks out about 1/4 inch too much and the brace is too wide to fit in the slot in the top plate.
