Gee
A Horse's Ass
Gee's Avatar
06.29.2008, 01:20 AM
The thing is that when I try to bind the receiver and transmitter, the green light never ends up flashing on the receiver. The instructions say to hold down the bind button while turning on receiver (I use switch on MM btw) and wait for green light to flash on receiver. Then hold down bind button on transmitter and wait for the green light to flash on the transmitter. Then lights on both should be solid... but I can't even get past step one of having lights go on on the receiver...
Should I plug in the rx pack into the bat port on the receiver? How do I turn the receiver on if the ESC is not plugged in...?
I hold the button in on the RX and plug in the esc or battery pack. The receiver will turn on as soon as you plug in a rx battery pack . You might be having problems with the MM using the UBEC. Try binding with out the ubec connected using a single battery or 7.2v battery connected to the MM and all three esc wires connecting to the RX. I think there is also an option in the MM setup to allow more time for you transmitter to synch (or something to that effect).
I understand you are having problems with the rx but just checking..... Are you holding the bind button in on the transmitter then turning on the transmitter power button on?
