06.30.2008, 09:46 PM
I have no idea if any other mounts work, but I would guess not since the overall height, mounting hole spacing, height of the bearing, etc. all need to match. But to make it easier on you, I have all those dimensions:
-mounting hole spacing: 21.0mm (like you said) at top and bottom
-overall height: 43.4mm
-distance between middle of bearing and bottom of mount: 22.0mm
-spur gear: 44t
If you could tell Mike those dimensions he could either just make a mount or find one that is similar and modify it.
