drkros3
07.01.2008, 02:12 PM
Originally Posted by azjc View Post
my latest thought is that I will upgrade my Rc18, here is a list
ESC Mamba Micro Pro
Battery FP 25 evo 4s 1500
Hyperion y-22 4400 long can or Neu 1105/2y
I am thinking about the diffs they are the weak point in the RC18s
for the diffs just use mip super diffs, delrin gears, 3 shims on the diff, and one shim on the gear coming off the shaft (i used a washer that goes behind the wheel pin) when u drive it slow its fells really tight but once you get up to speed it opens up and is pefect. i have not strpied a diff yet.
here is my setup
mm esc
8000 kv mamba motor
2 x 2cell 900mah 12c for a total of 1800mah 24c
