Duster_360
07.02.2008, 09:41 PM
Look at it - the side opposite the side with the 3 screws goes down against the batt. The small square window on this side is where the temp pickup and it should be in contact with the batt surface.
I use a rubber band to give mine good contact and stay in one place, for accurate temps, you don't want the sensor moving around. Been pretty impressed with mine, its a huge improvement over the temp sensor made for the Ice charger, and seems to provide a reliable, timely temp.
