evader
07.03.2008, 12:46 PM
it doesn't appear that the 2 pins are touching each other or anything like that.
I don't understand what is wrong with it when it worked for you when you tested it?
Just to make sure I have everything plugged in properly...the steering servo plugs into spot 1 in my receiver, the ESC goes into spot 2 in the receiver and the UBEC goes into the battery spot...is that correct?
