GriffinRU
07.03.2008, 09:32 PM
Originally Posted by evader View Post
It's hard because of the glare from the shrink wrap...but here's what I was able to get. The first one shows where it is supposed to be (I think) and the second picture shows that I can just pull it out...I could pull it out all the way if I wanted to...
That is how it should look like:
And looks like you correct the wire is loose...not good.
You can try to resolder or attach this loose wire to black (negative) battery lead connector.
