07.04.2008, 04:08 AM
Trial and error is often required in component placement. The bec usually poduces some interference and may require reloacting for best results. Braiding the motor wires, and making sure the antenna wire is not mixed up with other wires seems to be the best method for me. A clean, neat wiring job will often yeild the best result.
