BushyAR15
07.05.2008, 08:31 AM
Thanks so much! I was able to "program" my Radio to my ESC.
But still can't get my USBCOM+ to recognize my controller. I tried downloading the "Flasher" updater software, no joy....
The controller software sees the unit, but it says I need a newer version of the ESC software and to download it. But I can't based on my previous sentence.
So, if you wouldn't mind posting the way to program my ESC via the Radio, that would be SO appreciated!
When I power on the ESC via the main switch with the EPA for throttle set to max or 150%, all I get is the flashing red light. I reckon I must be in programming mode....
I guess I'm closer? Just need to be able to program the settings via the radio?
Man, I did a search based on pizzaman's suggestions and found that "$100 Reward" thread. I'm so in that boat right now.....
BTW, I noticed in that thread it says to set the "neutral" to like 9 or 12%. What is the "neutral" setting, EXP?
