evader
07.05.2008, 01:33 PM
Originally Posted by GriffinRU View Post
I am just wondering what you do to the controller...
Send it back I will fix it and epoxy everything around, so you can pull entire truck by wires.
If anything this last, unmarked wire, must be soldered to the tiny SMD resistor, cannot be soldered anywhere else. But then you can crack it if not done properly, carefully.
sent you a PM
