BushyAR15
07.05.2008, 07:14 PM
Well, that explains that :) I need the cc_03 cable....
Well, I re-programmed the ESC and radio to the default.
ITS ALIVE!
So, it works, but I need to program it to the Lipo Pack and get rid of reverse.
I read through the programming section of the manual. The section about programming via your TX.
OMG! I read through it several times and don't completely understand how to do it. I understand there is repetitive steps and you have to do the same motion to get to certain parameters. But it seems one mistake and you're starting all over again...
While I don't consider myself the brightest bulb, I am college educated and have been a software engineer since programming in Assembler was done on punch cards...
For setting parameters, you will need to connect the controller to USBcom with cc_02 cable. For updating, you will need cc_03 cable as well as v3.0 USBcom (or higher) and v3.20 or higer in the controller. Neutral setting is like the dead band between F - R.
