captain harlock
RC-Monster Captain
captain harlock's Avatar
07.05.2008, 08:53 PM
Car's specs:
The 801Xt is a 1/8 sale competition level assembly Truggy kit, designed and tested in Southern California, USA. The highly efficient drive system comes from the optimized placement of the front and rear propeller shafts. The drive line is virtually straight which offers the most efficient drive-line possible in its class. The 801Xt chassis has plenty of adjustability to fine tune it for the most demanding of race tracks across the globe. TRF drivers from all parts of the world will be piloting this new competition level truggy in the coming months in an effort to exploit its potential and further develop the new line of 801Xt options soon to come!
Kit Features
# 3mm A7075 hard anodized Duralumin chassis
# Machined aluminum shock towers, steering knuckles and engine mounts
# Low wear, efficient straight line drive train
# Carbon fiber servo plate and upper decks
# Sealed radio box
# Full ball bearings
# Sealed bevel gear differentials
# Spiral cut ring and pinion gears
# Lock nut captured suspension hinge pins
# Universal drive shafts
# 3 shoe aluminum clutch
# 15mm Large volume shocks with boots
# 17mm wheel hubs
# Front and rear stabilizers
# Turnbuckle brake linkage system
# Dual 32mm brakes
# High volume air filter
# Low profile polycarbonate body
# Adjustable turnbuckle linkages
# Chassis side guards
# High down force wing
# 150cc fuel tank
Specifications:
# Wheelbase: 373 mm-375 mm
# Width: 428 mm
# Length: 566 mm
# Dry weight: 9.2 Lbs (varies on radio gear & engine)
# Gear ratio: 15.35:1-16.54:1
# Fuel capacity: 150cc
# Engine size: .21-.28cc
Separately required items:
# Engine .21-.28cc
# Manifold & pipe
# Fuel filter
# Tires & Wheels
# Two Channel radio with two high torque servos
# 6.0 V reciever battery
# Fuel
# Paint for Polycarbonate body
NITRO KITS REQUIRE:
(unless stated differently above)
* Radio: 2-Channel with servo(s)
* Battery: 4 AA for Receiver
* Fuel: Nitro Glow Fuel
* Starting Equipment: Glow igniter
* Paint: Polycarbonate for spare body
* Misc. Items: Building and track equipment
http://www.tamiyausa.com/product/ite...oduct-id=49497
Nice to meet you!
