Originally Posted by Sammus
FWIW when my sidewinder esc first came a little while ago I accidently soldered my deans on backwards, I hooked it up, no go. I freaked out, unplugged, resoldered backwards again (This was not one of my better days  ) repeat, then got it the right way. the esc and batts were fine
I was in the process of disabling the on board BEC on my Mamba 25 for my RC18 and use an extra CC BEC I had... I programmed the BEC and wired everything up than when it came to pulling the red wire you can guess which red wire I pulled...
..than everyone was out of the BECs but the truck needs the diffs rebuilt anyways...so it continues to sit
