TDC57
TDC57's Avatar
07.07.2008, 12:42 AM
Originally Posted by q8-maxx View Post
Mike do I have to buy the new cover? because I had a cover from you before 2 month and I don't use it at all
And is this cover an important with new neu design? (the new design has about 3 empty extra hole) and 3 for the wires
Thanks
You should be fine, the cover is just an extra precaution to keep the dirt out. they are not required to run on a Neu motor, it does not slow it down, speed it up, or keep it any cooler.. Like Lincpimp says, black tape will also work.
Nothing!.. Hahahahaaa..
