George16
Supermaxx
George16's Avatar
07.07.2008, 10:14 AM
so shimmed stock gears wont hold up?
They will not last long. If you plan to use shimmed stock gear, use them with an aluminum diff cup to prevent flex and enlarged the pinion gear holes to accept 3mm screws. I had used stock traxxas gears, aluminum diff cup (kippsters) and pinion bored out to accept 3mm screws, shimmed and they lasted a long time. I have never broken one. I had since sold it in favor of the 6 and 8 spyders.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
