Thread: toughest 1/18
pipeous
5th Scale Guy
pipeous's Avatar
07.07.2008, 12:18 PM
Well I have had a few of these. I am a big micro fan. The Associated line takes a beating. Having ball ends at all the links is a plus. if you take a super bad tumble and such, usually a ball will pop off.... that means get cvd's cuz finding those stupid little springs in the dirt is a pain,... been there too many times. even the ft has blue aluminum dogbones instead of plastic but still those springs. you can put a dab of shoe goo on and push them in, and that usually saves them, but for $12 a pair it's not worth it
the driven production gear cover at the toyz is a must or you'll eat spurs. $13 well spent. the steering drag link or another nice setup helps. the stock servo saver has a plastic ring, at least get the metal ring for that. tightens the steering up. when building the shocks put a dab of shoe goo around the bottom clip of the shock body so they don't come apart doing big air. buy a couple extra difs and a set of bearings. after a good run just swap everything out and clean those up for next time. it's so cheap to keep a set and you will have a nice clean car always.
the xray is a sweet truck. it's drawbacks are you can only use xray wheels because of the hub setup. and it takes a special battery to fit. yuntong has a nice 1800 mah that is a tight fit. my bud has the xray, been a while since I owned one
I recently picked up an inferno09. I have to admit it handles like a much bigger rc. I was able to hold off a 10th brushless 4wd on the track and it wasn't even fair for me to run with the micros. it is a shrunken 8th scale buggy, with a solid center spool. I am going to make a motor mount and toss an align t rex motor into it and run 3s lipo. I am hoping I can drill and tap the flywheel and use the clutch, otherwise I'll just order some pinions from mike.
the electric inferno is not the same. you have to add bearings all over and such. the nitro has a much stronger platform to start with and the center dif has more of an offset (bud with the xray has an electric mini inferno so we compared a bit)
I have ordered a lot from thetoyz.com and the service is great. just waiting for tires, wheels and some goodies for my inferno right now :D I am an Associated guy through and through (even my crawler is a PTI Goliath and I need to fix a dif with TC3 parts hehe) but the Kyosho is in a league of it's own..... you can also find a killer deal if you find any of the kyosho lav8. it's the military vehicle version of the half 8. toyz had them for $100 rtr last I saw. am still tempted just because they look so cool
