sikeston34m
sikeston34m's Avatar
07.08.2008, 09:45 PM
OK, I swapped the motor out for a Nemesis 14xl (1191kv). Installed some really tall gearing. All Mod 1, motor pinion is 24 tooth, spur is 38 tooth. I'm sure this is over geared but I thought what the heck.
I swapped the Talons out for some E maxx Tires/wheels and gave it a run on 4S. Power is decent.
I then gave it a run on 5S 5000mah 20C Lipos.
It's pretty dang fast on this setup. 4 Wheel burnouts, and saucers are easy. Rolling wheelies at speed. Has alot of power. I'm really impressed with it. But the motor was starting to heat up after about 10 minutes.
How hot do these motors normally run? What is the ideal gearing with this setup? The power level looks promising. I can only imagine this on 6S.
