07.09.2008, 12:50 AM
Hi Soldier,
I've been thinking about giving the Medusa Motors a shot myself. I want the 036-060-2000V2.
Set your ESC to Race Mode, Dynamic Torque, Inrunner Mode (seems to work better even with multipole motors), Normal Braking
In my opinion, you are undergeared.
In Mod 1 gearing with that motor I would go 14/40.
If you're going with the 32 pitch gearing, you probably need a smaller spur and a larger pinion.
You might also try a heat sink with a fan if you're worried about temps.
I've heard those motors are pretty mean.
They are supposed to come out with a 70mm can model. That should compete directly with the cc neu motors, price-wise. I will most likely try out both when they come out. I want a low kv long rotor motor to replace the 14xl in my savage. I have a mega 22/45 motor that I need t try.
Too many toys...
