Finnster
KillaHurtz
Finnster's Avatar
07.10.2008, 10:48 AM
You should be closer to 38mph unless you are getting .5" ballooning...
Differential Ratio: 3.909090909090909
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 12
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 6.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.83 : 1
Total Ratio: 14.98485 : 1
Tire Circumference (inches): 20.73 inches (526.66 mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 40.41 mph (64.92 km/h)
Estimated Adjusted Speed: 38 mph (62 km/h) - 5% loss
Effective KV Value: 2084
I prob am, def even more so in the F under WOT due to the light fluid in the diff. I admit it was much higher than I expected, but I ran it several times back to back with the radar gun and it was consistantly 45-46mph.
