Thread: MM Heat Issues
azjc
07.11.2008, 01:11 AM
both of your motors you have listed draw a lot of amps, if you have the cash buy a couple of new motors that have a higher wind, and also check the timing for the ESC if they are not at 0 this will cause heat...running the timing does speed up the motor a little but not worth the heat buildup IMO
also make sure you are using an external BEC with the onboard bec disabled
