azjc
07.14.2008, 12:18 PM
Originally Posted by Ev1er View Post
so which motor will give me the longer runtimes ?
as a rule a lower KV gives you longer the run times and slower speeds, but you can make up the slower speeds by running more voltage
I like to run a higher voltage/lower KV in my setups but that becomes more expensive
when you run higher voltage you get less of an amp draw from the motor and this increases runtime and decreases heat
