07.15.2008, 07:31 PM
I used super strong velcro to mount my MMM, only trouble is when I went to remove it the bottom half of the esc case stayed on the truck... :/
Now I have a ziptie around the case, and the velcro as before, works fine. I wouldnt mind mounting ears, but its no biggie to me personally- I just wouldnt mind a case that was the same as it is now, but minus the built in fan housing in the upper portion. Instead, have a flat area with a grill, so that a larger 30-40mm fan can be mounted ontop of the case. Maybe make it an optional case so that there is no warrenty issue with people not using a fan- buy the optional case and the warrenty is stricter or something.
