07.15.2008, 10:20 PM
Usually, Deans or Traxxas connectors are the top choices. Some like the Anderson PowerPoles too. All of these are keyed and protected. By keyed, I mean it can be plugged in only one way to prevent reverse polarity. By protected, I mean that the contacts are insulated to prevent accidental shorting on any metal. The downside to these connectors is that they are only rated to around 50A, burst is a bit higher.
The larger bullet connectors can handle higher current, but due to their design, they aren't keyed. Someone could accidentally reverse the polarity and blow something. You can put a male and female connector on the battery as a form of keying, but then one contact isn't protected and increases the risk of accidental shorting.
What would be really nice, is some sort of plastic plug add-on that would allow 5.5-6mm bullets to snap in to provide the advantages of both types of connectors.
