VintageMA
VintageMA's Avatar
07.15.2008, 10:38 PM
Originally Posted by Dirtfreak15 View Post
im running 1/10 tires though... so idk
isnt a 8l like a 2765kv? should that be low enough of a kv to run with a 16t pinion and some 2.2 tires?
what size pinion where u using?
how hot was it getting?
When I was running the 1/10 buggy tires there were no issues with heat on 3S (the Hacker 8L is 3019kv) and 16/46 gearing.
When I upgraded to the RCM extended chassis I went with 30 series prolines (4.1 inch diameter - same is 2.2" truck tires) at the same time and the load was really heavy on the vehicle. That was the same time I started puffing MA 3S 5Ah packs - with a max 72Amps - ha 20C my A.
The 1512 is almost too much fun, on 30% punch on the MM I can still literally flip the truck over backwards if grip is good. The 1509 is just a great motor and works just as well as a LMT 1930. All great choices for the ext chassis.
For a standard chassis CRT.5 a ~3000kv motor on 3S with stock wheels is a great setup too.
“Everyone has a right to be stupid; some people just abuse the privilege.”
