bl-is-future
bl-is-future's Avatar
07.16.2008, 08:05 PM
bigger gear is second gear. Use jb weld to weld the gear to the clutch. Remove all other gears and good to go. THe small solid peice is the part for the brakes (mechanical brakes) it is how the shaft that rotates actually pushes out on the pads to slow it down.
