sikeston34m
sikeston34m's Avatar
07.19.2008, 12:06 AM
Originally Posted by kevin23 View Post
lots of torque,had the neighbors freaking out.
no way to radar,but I would guess the top speed to be around 35 mph,is that what you were getting out of the axi in the emaxx?
I moved the throttle deadband(what exactly does it do?),and have the timing on the highest setting now.will try it this weekend at the track.
I am happy with the performance,does exactly what I wanted.more efficient setup with more topend.I think it will be real good on our track
The Throttle Deadband is how wide the Neutral setting is on the radio trigger.
Yes, top end was around 35mph. But this setup accelerates pretty hard!
You should be seeing increased runtimes over your previous setup. I was getting about 25 minutes of runtime on 5000mah 4S setup.
I did try this on 5S. It screams!, but heats up very quickly. 5S is too much to keep temps under control.
