07.19.2008, 01:05 AM
Nice ride. Did you get the 83mph with the rubber or the foam tires? Also, I wasn't aware that the HV110 could handle motor braking, being an air controller. That is something to consider. Or, that MGM 12032 that I've always wanted! Also, also, I will be making a "cover" for the bottom of the car to reduce drag and keep the air getting under the body. A larger wing may be in order, too, and therefore an actual wing mount.
Edit: I haven't tried motor brakes because the Sentilon doesn't support them, for car duty anyways. Only to slow a propeller.
