Thread: Project Viper
B4maz
07.19.2008, 01:12 AM
Nice ride. Did you get the 83mph with the rubber or the foam tires? Also, I wasn't aware that the HV110 could handle motor braking, being an air controller. That is something to consider. Or, that MGM 12032 that I've always wanted! Also, also, I will be making a "cover" for the bottom of the car to reduce drag and keep the air getting under the body. A larger wing may be in order, too, and therefore an actual wing mount.
I tried both the rubber and foams and got to 83 using both. Before using the HV-110, I also thought it wouldn't be able to handle braking, but it handles braking fine.
The only thing I am having problems with is the Neu 2215/3Y. The endbell comes loose after a full throttle pass and the power of the motor goes waaay down. I have to send it back to Steve Neu so I can get the endbell secured.
Your car set up looks good. I wonder why you have traction problems. I know OFNA makes rubber slicks for the GTP. Maybe you can try those. You have a killer paint job. I cant stand painting and I am terrible at it. I just paint everything white, lol.
