TDC57
TDC57's Avatar
07.20.2008, 03:42 AM
Yuri..
I've got an 808 "E" http://www.rc-monster.com/forum/showthread.php?t=12322
I started it on 1515 1.5 y with 5s. WAY TOO MUCH POWER!, I've steeled down with a 1512 2.d S on 4s and couldn’t be happier and yes I’m whomping the Nitro guys with this setup.. So Best of luck with 6s in the 808..
Best motor on a 6s is the 1515 3ds, it rated for 8s so it will run really cool and provide you with a larger range of gearing options. I use this motor on my GEVO on 6s 52/22 (love it)
Also, you do know that your total height clearance for the 808 is about 43mm from the chassis to the body, just an FYI the largest mAH I was able to fit without shimming the body was 4500..
Best of luck with your build and post some pics when your able..
Nothing!.. Hahahahaaa..
