Thread: Maxamps Lipo
MetalMan
MetalMan's Avatar
10.08.2005, 04:29 PM
Originally posted by mothman
Metalman, is this charger really good? I was about to buy the ICE, untill I saw your post. Is this a CC/CV charger Ihave 5S lipo, so if I buy the ICE then i have to charge the battery two times. So what do ICE have that this charger dont have? ?
Ok, I just read about this charger in few forums. Many ppl are happy with this charger. It has some very nice features. Looking at the instruction sheet it appears that you set battery capacity, not charge current while in Li-Po mode. Does this mean that if I have a 3700ma Li-Po pack, I can't charge it at less than the 1C rate?
1C is the maximum charge rate, so I'm thinking that charging at less than maximum might increase the life span of the packs. Don't think I'm alone on that thought. At home I'm in no rush, so why not charge at a lesser rate.
By the way, astroflight is not a CC/CV. Im looking for a CC/CV coz its better to charge you battery with this. [/B]
I haven't heard any reviews on it yet. But if you have, and they are good, then that is good :L:. If you set the charger so that the battery's capacity is 3700mah, then it will charge at 3.7amps. You could just set it to a lower capacity, and it will charge slower. But this could be a problem, as the charger might not allow you to put more back into the battery than whatever you select for the battery's capacity.
The ICE has A LOT of features that this charger does not. Perhaps that is why there is a $40 difference. For starters, the ICE has a display that's about 8 times larger (it's a dot matrix display, the Multiplex's is just a 2-line). The ICE can show a graph of charge/discharge, which is an awesome feature IMO. It has a built in fan for doing high cell/high current charging/discharging. It has a 10 model memory, and can do 10 consecutive cycles for NiMh/NiCd. It can discharge up to 10amps, and charge up to 8 amps. It is easier to navigate because it has a nice wheel. It has a brushed motor break-in feature that can be used as a variable voltage power supply (or even as a BEC for use on the workbench). I think that's about it. Now, the only downsides of the ICE (IMO) are that it can only charge up to 4s Lipo and 10 NiMh/NiCd cells. If it could do more cells even for $20 more, it would be the single most popular charger on the market.
You are correct about the Astroflight 109. It is a "pulse" charger, not at all a CC/CV. If this charging algorithm were better than CC/CV, then there would be more chargers on the market that use it (it is probably the only one that does). CC/CV has to be a more popular method for a reason.
