Drifted Demon
07.20.2008, 07:08 AM
UPDATE
I successfully fitted 12awg wire to my MM. i used an 80w iron, i kept my fingers on the heatsink of the esc so i could monitor the temps. the 12awg wire fitted straight into the holes, even with the wire tinned & the solder tab holes tinned. i ended up using 60/40 rosin core, & cleaned all the old solder out with a solder suck.
