Originally Posted by kevin23
I'm all about modifying.
If only you saw my old tnx pro that I was racing,I went and changed the tank to a mgt,I made my own sway bars for it,used the traxxas flywheel setup and used the revo slipper and spur gear because the stock gear was sooo weak  anyway,
you talking about putting the heatsink compound between the motor and the motor plate?I will try that,I think I could pretty easily add some fans as you have on the maxx.
I have to wait and see where all the electronics go first
Yes, between the motor and the motor plate, but that motor plate then slide onto a post and mounts to another plate. There are several spots there that would benefit from the thermal paste.
I would add some to the post, then also where the two plates touch. Aluminum is such a heat sink.
The fans that I used are 25mm square. I power them with the CC BEC also. Remember it can carry like 10 amps. You could probably power a 100 of those small fans with one.
