tino_ale
07.22.2008, 04:38 PM
Ok I got my rustler running
I really have to say that I'm extremely impressed by this rustler VXL. I mean for the price you get a RTR model that includes everything, to hear it run is as easy as i can get, yet what you get is a BEAST of acceleration and top speed. It's almost criminal to sell that kind of stuff to anyone who has $270 in hands without a background check
I bought the FLM extended chassis along with it. Mounted everything was extremely easy. As I am more used to 4x4, this model just looks so simple and straight forward that my other models actually look very cluttered and messy now.
I initially planned to used two 3S A123 packs in parallel but I have tried to use them one at a time and they work extremely well. Runtime is very useable too, since the car is so lightweight. Unless you are really making speed run repeateadly it's easy to get 20 min of bashing around on a single charge.
Here are a couple of pics of my rustler. All stock except the FLM extended chassis :
My only complains are :
- all the scews run directly into plastic parts, no metal inserts, so you need to be carefull not to strip the threads
- the little protection behind the motor broke quite easily I ordered two spares but might also consider a more robust skid plate or something
Bottom line is I would totally recomment A123 for the rustler VXL. Only the FLM chassis is really needed to make this work, since a 3S pack would not fit in the stock chassis. You get some serious power for a very limited budget, and so far it work fine for me. It was very easy to make the packs from a Dewalt 36V since I kept the stock tabs. The rustler seems to have strong enough parts to take the power without breaking instantly.
Besides, charging in 15 min is just too good to be true, yet it is true. OK maybe 17 min is the pack is flat empty.
Thanks again for your input and cheers!!
Hey do you guys think I am abusing my A123 pack by using them one at a time? Should I stick to two packs in parallel (eventhough the car gets heavier) ?
