Thread: BEC vs Rx pack?
07.22.2008, 05:40 PM
Sammus - looks like your BEC is located right next to the Rx; I would move it as far away as possible to reduce glitching (Rxs are more sensitive than the esc I think).
Is there any real issue with using a normal linear voltage regulator instead of a BEC? Im assuming it will result in less glitching caused by noise, but run warmer (not an issue really)...
