bdebde
That's All Folks!
bdebde's Avatar
07.23.2008, 12:43 AM
well what diameter are the finned nue motors? i think the smooths are 39mm arent they and the finneds are 42mm. i know i could easily fit a 12 tooth or less with the XL and mikes heatsink and prolly the smooth can but i dunno about the finned, mike only has a 1512 2000kv finned neu while impackt has the 1512 1700 kv smooth can.
will the smooth can be good enough and where can i find a heatsink for it?
Finned can is 44mm. If 12t is smallest pinion that will fit with an XL (36mm), then a 15t would be the smallest you could go with a smooth Neu (39mm). And 20t with the finned (44mm).
.... The fined probably do run cooler, but how much...
About 20 F according to Steve Neu.
