blueb8llz
07.23.2008, 06:39 PM
ill try and see if any shims/washers would even fit, if not, i can use some electrical tape. as funny as it sounds, ive used electrical tape on some jobs and it holds up great hahah.
ill just poke the hinge pins through the tape. ill report back when the results.
im using a old fm radio. it had no problems with my other vechicles with it though. what do i do to check the neutral resolution? i tried the steering trim, sub trim, and the epa
